Does anyone make an articulating arm that we could use to orient a fiber scope into a fiber adapter, leaving the human operator's hands free to work with software that analyzes the image?
The product we are using is the Westover USB fiberscope, and it works with their Fiberchek software to analyze defects on the fiber tip. The problem is you have to really work to get the probe correctly centered on the fiber, and then somehow stretch your hand over to manipulate the mouse to work with their software. If there were a clamp on an articulating arm that we could drag over to the fixture, orient, insert, and then take our hands off and have the probe maintain the orientation and position, it would be really helpful to working with the software.
What options do we have?
