Greetings,
I'm new to all this, so hope you don't mind...
I'm looking for a (small) electronic component that can do an optical switch (mirror?) from 2 input fibers to 1 output fiber. So the following functionality:
-2 (glass fiber) inputs (preferable ST connectors)
-1 (glass fiber) output (preferable ST connector)
-all in visible light range (380nm-780nm)
-By using an electronic signal 1 of the 2 inputs must be directed to the output. So I can choose which input is switched to the output.
-Switching time is not important.
Any links/websites/names are welcome!
Thanks, Bjorn bhotting at planet dot nl
