Fiber Optics Polish fiber optic at home?
Subject Author Date
Polish fiber optic at home? Eric R Snow 07-19-07
Posted by Eric R Snow on July 19, 2007, 7:25 pm
Greetings All,
I have a couple old Bausch & Lomb fiber optic bore scopes. The lenses
they came with are good but the polished ends of fibers have some sort
of corrosion that greatly reduces the light transmission. The steel
ferrules at the ends rusted a bit so maybe it's rust on the fiber
ends. Whatever it is it does not come off easily so I think I need to
try some sort of abrasive. Is there a household product that might
work? Like Bon-Ami? I don't want to ruin the scopes. One is cleaner
than the other and the light transmission is much better so I know
it's not the fibers themselves attenuating the light so much.
Thanks,
Eric R snow
Posted by danek on July 20, 2007, 9:40 am
Eric R Snow wrote:
> Greetings All,
> Thanks,
> Eric R snow
You can get lapping film for cheap from Fiber Instrument Sales. Just
add water and keep the end perpendicular to the film and go in figure
8's. Start with the course grit and work to the fine adding water as
needed.
P. Danek
Posted by Eric R Snow on July 20, 2007, 5:32 pm
>Eric R Snow wrote:
>> Greetings All,
>> Thanks,
>> Eric R snow
>needed.
>P. Danek
Thanks For the quick reply. I'll google 'em and place an order.
Eric
Similar ThreadsPosted
Polish fiber optic at home? July 19, 2007, 7:25 pm
Sell Fiber Optic Splice Closure,Splice Enclosure,Fiber Optic Closure,Optic Fiber Cable Connection Box December 1, 2005, 11:58 pm
Re: Please help me i've to connectorized an optic fiber September 7, 2006, 10:47 am
Fiber Optic Networks February 28, 2007, 5:25 pm
Undersea Fiber Optic Cabling October 13, 2005, 12:21 am
Pixelation in fiber optic scope November 4, 2005, 3:50 pm
differences between FC/PC and FC/APC fiber optic connectors September 20, 2006, 6:44 am
New Fiber Optic Cable Specs and Information Website October 20, 2005, 10:06 am
We are professional fiber optic equipment manufacturer-www.fiberer.com August 25, 2007, 11:13 pm
Need fiber optic suggestion for 900nm/4mm dia./100mm long/120 deg view angle June 1, 2007, 7:03 am
Fiber to Fiber Coupling April 22, 2007, 2:26 am
Fiber in NYC October 1, 2005, 7:11 pm
where can i buy some bragg fiber September 21, 2005, 1:22 am
Identifying fiber September 28, 2005, 8:15 am
Fiber Cladding November 19, 2006, 6:58 am
