hello ,
take a look of this software for arp spoof technology testing
Arcai.com netcut 2.0 released
take a quick look at Download At
High intimate :Pure ARP protocol kernel.enhenced cut off funcation, that no one can escape from your cut off unless he have netcut installed and with protected funcation enabled.
Easy to use: One click to Protect user Computer Function!!! No one in the network can cut you off with ARP spoof technology anymore .
Effective: one Click to Cut down any computer s network connection to the gateway. IYFT:Get all IP addresses of the computers in your LAN(Local Area Network) in Secs High applicability:Work in office LAN,school LAN,or even ISP LAN Have Fun with play the online computer make them online or off line remotely Safe: TRACE Free, No one will TRACE out what happen and last More Stable,swich-hub or hub or cable lan any Lan use Ethernet
Download At
NetCut is a Software that helps you admin your network by purely on ARP protocol . List IP-MAC Table in secs, turn off & On network on any computer on your LAN including any device like router , switcher. Also, netcut can protected user from ARP SPOOF attack
