Ethernet LAN what gigabit switch (8 port) to select
Subject Author Date
what gigabit switch (8 port) to select Gilles Vollant 03-06-07
Posted by Gilles Vollant on March 6, 2007, 1:23 pm
Hello,
I'll need but a gigabit switch, 8 port.
I found D-Link DGS-1008D or Netgear GS608, by example
I found no test, what is the better gigabit switch for 8 ports, which is
not very expensive?
Posted by Harald Andersen on March 7, 2007, 6:00 am
> Hello,
> is not very expensive?
I recently bought this one "3CGSU08-ME"
http://www.3com.com/prod/fr_FR_EMEA/detail.jsp?tab=features&sku=3CGSU08
In Norway it costs Kr. 650,- NOK = ? 81,15 EURO
For its price, you get a good name, and a fancy look ;->
I had to put black tape in front of the LED's as I cant stand
that STRONG flashing blue light.
/Hca
Posted by phn on March 7, 2007, 1:24 pm
> Hello,
> not very expensive?
You usually get what you pay for. Cheap one are - cheap. You really
must ask
yourself "how much performance do i need" "and how do i figure out
where my
bottleneck is". A cisco 4948 would give you top performance, but can
you
fill it ?
Said that, get a cheap one, chances are that the bridge is not your
bottleneck.
Posted by glen herrmannsfeldt on March 7, 2007, 1:41 pm
phn wrote:
(snip)
> You really must ask yourself "how much performance do i need"
> "and how do i figure out where my bottleneck is".
> A cisco 4948 would give you top performance, but can you
> fill it ?
I believe that there are chip sets, or maybe a single chip
for the smaller switches, so all one has to do is build a
box and power supply around one.
> not your bottleneck.
For home use, I would agree. It might be that more expensive
ones have a better power supply, for example, and would be
better in some environments.
-- glen
Posted by Rick Jones on March 7, 2007, 3:04 pm
Not sure if it is in the desired price range, but HP ProCurve has an 8
port Gigabit Ethernet switch out there now:
http://www.hp.com/rnd/products/switches/ProCurve_Switch_1800_Series/overview.htm
are managed versions, and then there are:
http://www.hp.com/rnd/products/switches/switch2708-2724/overview.htm
which are unmanaged. I've had occasion to use the 2724 myself and was
happy with it. I've not had occasion yet to try the 1800's - while
I'm not in the ProCurve part of the HP house, the old saying about the
cobblers children still applies :)
rick jones
portable adj, code that compiles under more than one compiler
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH...
Similar ThreadsPosted
what gigabit switch (8 port) to select March 6, 2007, 1:23 pm
Cisco vs. Netgear: 24 port gigabit managed switch February 10, 2006, 4:44 pm
difference b/w inter-switch link port and trunk port July 6, 2008, 12:06 pm
Port on switch going crazy........ October 2, 2006, 11:48 am
16 port unmanaged switch April 15, 2007, 4:22 pm
Sharing a switch port August 30, 2008, 3:17 pm
Switch Killed Computer's LAN port April 3, 2005, 3:04 am
Switch performance with many-to-one port traffic October 1, 2006, 10:21 pm
Anyone know of a vendor which makes a 12-port 1000BASE-LX Switch? July 24, 2004, 1:33 am
Experiences with Compex CGX3224 24-port switch? September 17, 2004, 7:42 am
Assign static IPs to port of a managed switch June 24, 2005, 1:42 pm
Media converter vs Switch with Fiber port January 11, 2006, 10:04 pm
obtaining port bits per second data from switch August 29, 2006, 12:20 pm
Safe.com 8 Port 10/100Mbs Fast Ethernet Switch February 13, 2005, 12:49 pm
gigabit switch chip August 23, 2004, 5:23 am
