Hi there. I am trying to locate a DEC/Compaq/Cabletron VNSwitch 900CG Fast Ethernet/Gigabit Module Installation and Configuration Manual. This module is for the DECHub/MultiSwitch 900 with firmware v5.5. I am trying to reconfigure this module since it came from a different production system, but I have no clue how to access it. The 900CG currently only has the top two green LEDs on, and the single top RJ-45 port works at 10MBps, but the rest of the 8 Fast Ethernet ports do not light up when I plug a PC into these ports.
I do have terminal access to the DECHub 900 chassis, and I did do a factory-reset of the configuration. VNBus setup is on. However, I cannot seem to access the VNSwitch 900CG.
Any ideas?
