Hi Guys,
I need to get a VGA signal from the Nav Station in my boat to the monitor in the bridge. I could just run a VGA cable (about 4m worth) but I need to pass the cable through some small holes for the looming (sp?) and the DB15 connectors wont fit unless I make the hole bigger.
I am thinking about running the VGA singal over CAT5e, which a Google search seems to suggest is possible. I was wondering if anyone had any better ideas, keeping costs fairly low.
Has anyone here had any success cutting the end off a VGA cable and wiring on a new DB15 for example?
Thanks in advance,
-Al
