Is 00 00 00 00 00 00 a valid mac address which could be subjected to learning and forwarding ?
Thanks in advance Srinivas
No.
But that doesn't mean that misconfigured or malfunctioning equipment will never generate it.
There is nothing syntactically *invalid* about that address, either as a SA or a DA. However, since the OUI 00-00-00 has not been assigned to any equipment manufacturer, no device should be using it. That said, it is possible that a device may emit frames to/from that address under fault conditions (e.g., the device is broken in some fashion), so a *receiver* (e.g., a bridge or end station) should be prepared to deal with frames sent to/from the address, and not produce undesirable results.
-- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Didn't some antique machines, I dimly remember Suns perhaps, use the all 0s MAC address as a broadcast address?
Bert
Bert
Also, some higher layers assume that the all-zero address is a place holder for an unknown MAC address.
Hmmm, interesting,
Albert Manfredi wrote: (snip)
(snip)
SunOS by default uses the 0 broadcast IP address. That is, all 0 for the host part instead of the more usual all ones. Manually setting the broadcast address on ifconfig fixes it.
As I understand it, using this on a normal network can generate broadcast storms.
-- glen
I believe that that "assignment" is simply a placeholder; Xerox "assigned" it to itself (and never used it) because RFC1042 specifies the use of the 00-00-00 OUI for SNAP encapsulation of Ethernet Type fields. At the time of RFC1042 (the early 1980s) there was no better "authority" to assign it to.
That is correct; this address block includes the multicasts used for the Spanning Tree Protocol and PAUSE flow control.
Minor nit - as of 802.1ad, some of these addresses are specified as non-reserved for provider bridges - they get forwarded just like regular multicast frames in the S-VLAN component of provider bridges.
Anoop
I once knew a net that had such a device. As there was only one, the decision was to just leave it alone. One possibility is an address stored in EEPROM that gets cleared and no new address set.
-- glen
Occasionally a vendor will forget to program the MAC address for a card (or run of cards) and then it'll sometimes come up as all zeros.
