Configuration: 14 PC's Side A; 5 PC's on Side B Side A: 1 x 3Com 24-Port Switch ->uplink to... 1 x 8-Port Switch (Have tried Intel & Asus) -> uplink to... Side B: 1 x 8-Port Switch (Have tried SMC & identical Asus) (Switches have auto-sensing and 3Com has uplink port.)
My uplink between two buildings was working fine for 5 months until it started dropping intermittently - once a day, once every two days or more often, there is no pattern. When the link goes down Side B can still browse pc's on their segment and 3 pc's on Side A, connected to the same switch that has uplink to Side B, can still browse Side A. The original cable run was CAT5 STP of 160m. I have split the cable into two 80m segments with an Intel switch in the middle without success. I have replaced the cable without success. I have currently got a 60m cable in place which runs directly between the buildings, thereby eliminating the possiblity of EMI from factory machines or heavy duty power cables. With this 60m cable I have placed two identical Asus GigaX 1008 switches on either end without success. I have run Etherpeek to monitor packets over the network without any unusual traffic ie. no excessive broadcasting or flooding. I have run AntiVirus and Anti-Spyware scans on all the machines in Side B without any problems detected. I would like to know if someone has had a similar experience and what possible solutions I can try. I would like to know the cause before I recommend a fibre or wireless link between the two buildings, and hopefully I can go back to using the 160m run which worked for so long.
Thanks.
