Unique MAC Addresses?!?!?!?!?!
Threaded View
Yo,
I work with networked medical equipment and there are several companies tha
t manufacture devices that are dual honed, where the device is specifically
 designed to have each NIC connected to a separate VLAN.  So the manufactur
ers actually assign the same MAC address to each NIC.  Duh?!  In response t
o this, I just finished reading ISO/IEC 15802-1, and strangely, I didn't se
e anything that stated, or implied that MAC addresses have to be unique.
What's up with this?
Thanks,
Ed
Re: Unique MAC Addresses?!?!?!?!?!
the.loquitur@gmail.com wrote:
Yes. As well as I understand it, when the standard was made that
was one of the choices. The only one I ever knew to do it was Sun.
Specifically, the address was in ROM on the CPU board, and was used
by all ethernet ports on the machine.
Then again, that was before VLANs were invented.
Well, yes, they have to be unique, but is it by port or
by host. Both are allowed.
Works fine unless you want two (or more) in the same LAN.
-- glen
On Thu, 18 Apr 2013 05:09:02 +0000 (UTC), glen herrmannsfeldt
Some protocols encode layer 3 info into the MAC address - main one was
Decnet phase 4.
A Decnet router would end up with the same MAC address on each
interface on the same logical area. AFAIR XNS was similar.
Routers which also handle other protocols and alloow this stuff to be
configured dynamically such as a Cisco would have multiple MACs per
port - 1 native + 1 for a Decnet config on the port and so on.
A lot of VLAN capable bridging kit now operates with MAC table per
VLAN (or the VLAN tag is part of the look up table)
You need this even with unique MAC addresses if 2 VLANs on the same
switch are linked via layer 2 bridging elsewhere, since your unique
MAC will end up being known in both VLANs.
Since that bit works, same MAC on multiple interfaces from a host will
work as well by side effect
- but bridging between VLANs at that point generates huge confusion as
the apparent ports for the traffic source switch around as packets
arrive from different sources
Regards
stephen_hope@xyzworld.com - replace xyz with ntl
Hi Ed,
The U/L bit in the MAC address (U for universal and L for local) is
never checked in bridges. It's up to the user to take care for having
a unique MAC address in the VLAN domain.
There is no problem to exchange data between 2 equipments in 2
different VLAN with the same MAC address. Each VLAN domain is
associated to a distinct IP subnet.
Best regards,
MIchelot
Site Timeline
