I have a Netgear RT314 Gateway Router. Because of a previous network setup, I turned off DHCP in this router. Now I can't figure out how to turn it back on. My PC now has a public IP assigned by the ISP's DCHP server, not an IP of the 192.168.x.x variety, so I can't telnet or browse to 192.168.0.1. If I connect the ethernet from the cable modem to the "Internet" port of the router, I cannot connect to the outside world. I have to connect the router as a simple switch just to use the internet. I tried to connect a serial cable method from PC to router and use hyperterminal, but had no luck. (I have never used the serial com ports on this PC before so I have no idea if they work or not). Is there any other method to get the DHCP turned back on? Any way to get it back to factory defaults?
diagram of current setup | cable modem ----------| |"Internet" port | ____|_____ | | RT314 | | |__________| | | | | | -----------| PC ------PC
