Hello - I'm trying to troubleshoot a problem where the output voltage on certain switch ports is outside of the 950 - 1050 mVolt range. This is found using a Tek scope. Does anyone know of a handheld tester that can test this, as I may need to test a bunch of switches deployed in the field, and taking a scope there isn't really feasible. Thanks for any ideas.
Dan
