Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Tester on April 17, 2007, 10:40 am
Please log in for more thread options Hi there, How would I go about finding to what port does the uplink port 48 from a Dell 3448 switch is connecting to another HP 2824 switch through switch commands? I am not able to track the cable between floors. Thanks a lot, Calin | ||||||||||||||||
Posted by DLR on April 17, 2007, 1:56 pm
Please log in for more thread options Tester wrote: others? | ||||||||||||||||
Posted by Walter Roberson on April 17, 2007, 9:54 pm
>Tester wrote:
>> Hi there,
>> How would I go about finding to what port does the uplink port 48 from >> a Dell 3448 switch is connecting to another HP 2824 switch through >> switch commands? I am not able to track the cable between floors. >> Thanks a lot, Calin >> >See which one has multiple Mac addresses or way more packets than the
>others? Also, looking at the spanning tree root might work, depending on which direction the spanning tree is pointing. If you are able to ping the Dell from the HP itself, then the Dell's own MAC will appear in the MAC tables on the HP, associated with the downlink port. | ||||||||||||||||
| Similar Threads | Posted |
| switch ports interconnection | April 17, 2007, 10:40 am |
| Seen any cigarretpack-size 4-ports switch? | February 8, 2006, 2:14 pm |
| switch ports are frequently disabled | February 2, 2007, 4:31 am |
| rack switch ports on back | April 13, 2007, 9:09 pm |
| Ports for MSN Messenger | April 14, 2005, 1:00 am |
| SOHO routers with 10/100 WAN ports? | April 8, 2005, 11:21 am |
| redundant ports in trunk | January 10, 2006, 7:25 pm |
| PCI Ethernet Card With Five or Six Ports | September 4, 2006, 4:24 pm |
| How to find out which ports are closed | May 11, 2007, 8:08 am |
| Two WAN ports comingout as uplink, I need to trunk them, how? | February 4, 2005, 1:12 am |
| Alcatel Switches and span ports | June 15, 2005, 3:54 pm |
| Extreme Summit 200-24 Dropping Ports | May 12, 2006, 9:50 am |
| configring trunk ports on Dell 6224 | March 8, 2007, 8:45 pm |
| Auto-negotiation and traffic flow between different speed ports | December 6, 2005, 8:15 am |
| Black PoE VoIP phone--PPoE-8,with 2 Ethernet Ports. | December 21, 2005, 8:22 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks a lot, Calin
