Is there any way that I can detect a swtich port's speed and duplex settings via Wireshark? Failing that, does any one know of a utility that I could use?
Thanx, Ed
Thanx, Ed
Starting with the easiest, if you have physical access to the switch you may be able to observe its front panel status LEDs. Failing that, if it's a managed switch you may be able to log into it and view the status of each port. If it's unmanaged, you can check its spec sheet or check the port status of the devices connected to it.
Just tossing out ideas...
You did not tell your platform and the answer differs a great deal between them.
To start: wireshark typically does not have access to the MII-bus, which is where these things are managed.
With most BSD variants (including OSX), ifconfig helps: $ ifconfig re0 re0: flags=8843 mtu 1500 ... address: xx:xx:xx:xx:xx:xx media: Ethernet autoselect (100baseTX full-duplex) status: active inet xx.xx.xx.xx netmask 0xffffff80 broadcast xx.xx.xx.xx inet6 2001:xx:xx:xx::xx prefixlen 64
$ ifconfig -m re0 re0: flags=8843 mtu 1500 address: xx:xx:xx:xx:xx:xx media: Ethernet autoselect (100baseTX full-duplex) status: active supported Ethernet media: media none media 10baseT media 10baseT mediaopt full-duplex media 100baseTX media 100baseTX mediaopt full-duplex media 1000baseT media 1000baseT mediaopt full-duplex media autoselect ...
On Linux, there are several mechanisms and I'm not aware of a generic mechanism. Check 'miitool'.
I do not know details on Windows, sorry.
Geert Jan
If you are running wireshark on a station connected to the switch port, chances are quite good that the station's speed and duplex match that of the switch port. In fact, if you see anything at all, it means the speeds match. The switch port could have a different duplex setting than the station though. Something from the mists of time, check the bit about signs of a duplex mis-match:
How 100Base-T Autoneg is supposed to work:
When both sides of the link are set to autoneg, they will "negotiate" the duplex setting and select full-duplex if both sides can do full-duplex.
If one side is hardcoded and not using autoneg, the autoneg process will "fail" and the side trying to autoneg is required by spec to use half-duplex mode.
If one side is using half-duplex, and the other is using full-duplex, sorrow and woe is the usual result.
So, the following table shows what will happen given various settings on each side:
Auto Half Full
Auto Happiness Lucky Sorrow
Half Lucky Happiness Sorrow
Full Sorrow Sorrow Happiness
Happiness means that there is a good shot of everything going well. Lucky means that things will likely go well, but not because you did anything correctly :) Sorrow means that there _will_ be a duplex mis-match.
When there is a duplex mismatch, on the side running half-duplex you will see various errors and probably a number of _LATE_ collisions ("normal" collisions don't count here). On the side running full-duplex you will see things like FCS errors. Note that those errors are not necessarily conclusive, they are simply indicators.
Further, it is important to keep in mind that a "clean" ping (or the like - eg "linkloop" or default netperf TCP_RR) test result is inconclusive here - a duplex mismatch causes lost traffic _only_ when both sides of the link try to speak at the same time. A typical ping test, being synchronous, one at a time request/response, never tries to have both sides talking at the same time.
Finally, when/if you migrate to 1000Base-T, everything has to be set to auto-neg anyway.
Leaving the boilerplate behind... If the speed is 1 GbE, 99 times out of ten the duplex will be full - while the GbE specs allowed for half-duplex operation at 1 GbE speed, I don't know of any kit that shipped which actually did that.
Even if you aren't on a station connected to the switch port, if the wireshark trace shows data flowing through the switch port above
100Base-T speeds, you can reasonably assume the switch port was full-duplex and operating at 1 GbE speed. If the data is shown flowing at > 1 GbE then you can probably assume 10GbE.There are some exceptions though - certian GbE kit could operate at
2.5 GbE, though I'm not sure if it ever did so outside of an HP Blade environment? Speaking of an HP Blade environment, it would be I/O modules rather than switches, but the "flex NICs" there can be configured to run in any multiple of 100 Mbit/s.rick jones
