I have a traffic generation device which has plenty of 10/100 copper ports available, but the receiving device only has gig fiber ports. I don't need to generate lots of traffic, 100Mbps is much more than adequate.
I'm searching for the best switch (new or used) which could be used for this type of media conversion.
Ideally, I'd like a switch with the same number of gig ports as 10/100 ports. Generally the ratio is much different (eg, 24:2 or 12:1).
Any suggestions for a candidate device?
[I realize tecnically it isn't a true 'media converter' in the sense that they're using different speeds and hence 'switch' is the more correct term. However, 'media conversion' really is the only thing I'll use it for, and I won't be pumping data back to the 10/100 port at anything greater than a few Mbps, so I'm not concerned about oversubscribing in that direction.]Thanks,
-Bob Andover, MA
