Ethernet LAN slow TCP connections due to very different speed of segments?
Subject Author Date
slow TCP connections due to very different speed of segments? alainjean 03-10-05
Posted by on March 10, 2005, 5:08 am
Hello group/list,
I've checked the FAQ but I couldn't find any reference to this issue.
Our campus LAN is mostly Gigabit Ethernet fiber and 100 Mb/s UTP
distribution, but we still have some distribution done to remote parts
of the campus done over LRE (long range Ethernet), which is much like a
"local DSL". It's supposed to give 10Mb/s under the best conditions
AFAIK.
People from these remote locations complain that traffic to servers on
the core network is very slow. I've ruled out problems at client or
server side. I've tested file transfers across the LRE segment and
across the Gb Eth. segment. Their speeds were close to the expected
max, so this (I guess) rules out problems on the segments themselves
(esp. the LRE). I'm starting to wonder whether the big drop in speed
between the two segments isn't the root cause (I mean, a 1Gb/s and a
10Mb/s segment). Would Ethernet gurus be so kind to comment? (I'm a
poor system admin, acting as a network admin!).
The exact topology is as follows:
(Core LAN)
[Cisco Catalyst 4006 L3 switch]
1Gb/s Eth fiber
[SMC L2 switch]
100 Mb/s UTP
[Cisco LRE 29xx switch]
phone cable
[LRE end equipment]
100 Mb/s UTP
(client PC)
Thanks in advance for any comment, tip etc.
NOTE: the From: e-mail address is a dead one. Please post.
Greets,
_Alain_
Posted by on March 10, 2005, 4:32 pm
There is no issue with the speed mis-match that you describe.
TCP was designed to operate in that environment and as
is witnessed by the internet and other WANs does actually
does so.
Performance problems are always tricky, if you don't know
quite a lot about how this stuff works and can use tools
like packet sniffers and interpret the results it could be
quite difficult.
1.
The absolute first thing is to check the counters on all
of the equipment to see of there are errors accumulating.
Fix them. Any on Ethernet will most likely be caused by
duplex mis-match.
The error rate is basically zero on this kit now and
less than 1 in a million is OK. TCP is very good at recovery
and can hide much higher rates. On LANs most ports
have zero errors *ever*.
2.
Make sure that the performance is not actually as designed.
This is much harder. For example some users may complain
that windows file copies are very slow when they drag a directory
across the link. It casn take many net transactions to get even
one file across so the performance degrades quite quickly with
hops and or other latency and or slow links.
Eg to copy a file windows might do:
I made the details up but it is pretty close (I think).
Hello is filex there - wait on reply
Hello are you still there - wait on reply
Open file - wait on reply
Close file - wait on reply
Read first block - wait on reply
there was only one block so:
Close file - wait on reply.
Thats 7 transactions just to copy one tiny file.
Windows also keeps its explorer widow up to date
so that can be another load of transfers.
You can see this with a sniffer^h^h^h^h^h^h^h Ethereal.
I am now a convert. FAB.
Posted by Robert Redelmeier on March 10, 2005, 4:49 pm
> to servers on the core network is very slow.
Gee ... people complain? :)
> I've ruled out problems at client or server side. I've
> tested file transfers across the LRE segment and across the
> Gb Eth. segment. Their speeds were close to the expected max,
Both directions? When users were complaining? I typically
run ttcp and ping
> I'm starting to wonder whether the big drop in speed between
> 10Mb/s segment).
AFAIK, ethernet itself isn't the issue, but that Crisco bridge
may be. TCP/IP has a discovery mechanism that can work well,
but hasn't always been well implemented (especially MS-Win9*).
I also believe some of the newer p2p apps use UDP. You may need
to sniff the link.
It gets into Quality-of-Service issues, but if someone is hogging
that 10 Mb/s line, everyone else will suffer. Paradoxically
worse (latency) if the Crisco or LRE has big buffers.
-- Robert
Posted by Rick Jones on March 11, 2005, 1:09 am
> that 10 Mb/s line, everyone else will suffer. Paradoxically worse
Of course, if the buffers are too small - say smaller than they
typical TCP windows being used, a burst of traffic from the fast side
may fill the buffers and overflow. Checks of the statistics might be
in order - both netstat on the end systems and link-level on each side
of that 10 Mbit/s pipe (or anywhere there is a speed change I
suppose).
rick jones
The computing industry isn't as much a game of "Follow The Leader" as
it is one of "Ring Around the Rosy" or perhaps "Duck Duck Goose."
- Rick Jones
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to raj in cup.hp.com but NOT BOTH...
Posted by on March 10, 2005, 10:45 pm
Thanks to you Robert, FAB, Rick for all the input.
I'll do another pass of investigation based on your comments, but here
are a few more words on this, though:
- duplex mismatch: I've checked this all along the path, no duplex
mismatch (esp. the UTP link between the SMC and the Cisco LRE switch)
- this problem seem to happen all the time. When I've done my tests,
I've used ftp transfers (from Unix boxes, so that I know at least that
the ftp server is decent). Yes, the slowness was in both directions,
although, as expected, download was always signficantly faster than
upload.
Ping times were normal. I'll try ttcp too, thanks.
- I've concentrated on one complaint from one user who's making ftp
transfers only... we don't allow P2P on the University campus anyway
- the LRE links are not shared, so no one can be hogging them
My guts feeling is that somehow data gets pushed too fast over the fast
link and that either of the SMC or Cisco LRE switches drop frames. I
understand that normal TCP window mechanisms should take care of that,
but I suspect that they
don't, somehow, and I'm not sure how to check this (where can I find
something about this in netstat output BTW?).
Any new hint is welcome, I'll followup after a new round of checking
counters and such.
Greets,
_Alain_
Similar ThreadsPosted
slow TCP connections due to very different speed of segments? March 10, 2005, 5:08 am
UTP 'segments' March 10, 2005, 11:41 am
repeaters recreate signals to other segments, why not reflections? September 12, 2007, 3:17 pm
Slow down of internet service November 27, 2005, 7:08 pm
Using Jumbo Frames & Gigabit - Actual BPS is slow ! September 17, 2004, 10:39 am
slow smtp issue/packet capture December 18, 2006, 10:24 am
killing ethernet connections October 28, 2005, 2:02 am
multiple connections between 2 switches October 30, 2007, 5:45 am
Dropped packets/broken TCP connections August 23, 2006, 9:48 am
VLAN 2 Internet Connections. Send PC's down 1 ISP, VoIP phones down 2nd ISP April 1, 2006, 8:08 am
baffling speed problem July 23, 2005, 5:52 am
Network Speed Question September 2, 2006, 5:31 am
network card speed February 8, 2007, 10:32 am
Software to test network speed? September 9, 2004, 9:05 pm
Speed limit of Fast Ethernet November 22, 2005, 7:39 am
