In *theory*, the CFI bit would be used when an Ethernet backbone is carrying traffic being bridged from another LAN that supports "big endian" bit format, i.e., 802.5 Token Ring or FDDI. In *practice* there will never be a CFI bit on an Ethernet, since both 802.5 Token Ring and FDDI are obsolete technologies. You are looking at historical artifacts from the evolution of networking.
"In theory, theory and practice are the same. In practice, they are not."
-- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
