Comfort and peace, I wish you.
Here is a free access....(this may help you test/learn stuff about ethernet, this system is actually on a homeplug device connected via cable modem)
telnet to 98.215.91.249 on port 2033
About breaking something, do not worry.
username: root
password:
(just hit "enter")
To you, I decided to provide root access. Root access, will, help you to learn.
This is a non-global zone, so, certain features may be not present.
You may, on this system,install packages(install web servers etc), you may, install patches(learn how to patch a Solaris system), you may install software, etc.....
Try to keep connection on, sometimes the connection may, "time out"....I'm working on fixing it.... Play around with the system..learn, enjoy..
What I may do to help, let me know. How to connect to the system: You may, on the dos prompt, type: telnet 98.215.91.249 2033 (the spaces between, the word, "telnet", and, "98.215.91.249", and, "2033" are important)
Kartik Vashishta
