X-posting to the Cabling newsgroups
I have seen the light and am going to replace the regular Cat5 cables on
> my radio links with shielded - using Ubiquiti's ToughCable Pro. >
> With shielded RJ-45 plugs, I see "Internal" and "External" as in
> Internal:
> External:
> For somebody who doesn't use that many - as in a hundred being a
> lifetime supply - the no-brainer would seem to be the "External" style
> because it can be used anywhere, not just with devices that
> automagically forward the ground from the shell of the connector their
> AC ground wire.
> Does this make sense? Or am I missing something.
> Ubiquiti NanoStations with POE Injectors.
> Pete Cresswell
