Does anyone know how to resolve the following situation:
I have a VLAN switch that has three ports: port 1 is connected to network uplink, port 2 is connected to a server, port 3 is connected to a desktop. I'd like to make the following scenario to work:
In preboot environment (EFI), I need to use an application from the desktop to send packets to the server (port 2) and use another application to send packets to network uplink (port 1). In OS environment, all packets should send packets to network uplink (port 1). To support this scenario, what should the switch be configured? Can using PVID resolve this problem, for example we set PVID port
1="1", PVID port 2="2", and PVID port 3="1" or "2", so packets arrived at port 3 will be tagged with its PVID number (either "1" or "2") by the switch and forwarded to port which has the same PVID number (but this won't work since port 3 need to be able to forward packets to port 1 and port 2 depending on the application.Thanks so much for the help.
