Hi to all I am Vikrant, doing training in embedded Techonology.
So my question is ,
1: What the difference between a layer 2 switch which is supporting only port-based vlan or it support tag (Q) based vlan. Is the both are supported by a layer 2 switch (means for sending data to another switch then ieee 802.1q trunking protocol is used and in rest of case the port based vlan is used).2: Is the number of vlans a switch supports is depends on , switch's controller (means in some switch mannual it 's mentioned that this switch contains 32 vlans)
3: Please tell me in detalis about a single instance Spanning Tree Protocol with multiple vlans.In waiting of u;r reply... Thanks....
