We are trying to create a redundant internal network with the following configuration :
[ports b1, b2, c1, c2, d1, d2 ] [ on each switch is connected ] [to the same port on the other] /-------------\\ /-------------\\ | Procurve | | Procurve | | 5308 |--------| 5308 | core switches | | | | \\-------------/ \\-------------/ | | | | | | | | | | | | | | \\---\\ /--/ | | | | | | | | | | | | | | | | ---------------- | | | | | Procurve 2848| | | user switches | | ---------------- | | | | | | | | | \\-------\\ /---------/ | | | | | | | | | | | V | ---------------- | | | Procurve 2848| | | ---------------- | | | | | \\-----------\\ /-------------/ | | | | ---------------- | Procurve 2650| ----------------i.e. on each 'user' switch, there will be two uplinks to our core switches. I setup a monitor port on each of the switches and could see the entire network traffic on all of the switches.
I understand this is because I have not configured each of the user switches to recognise that there are two uplinks. The core switches see all possible mac addresses in each of the user switches, because all mac-addresses appear to be connected to a switch plugged into the other uplink port.
I tried configuring through the menu system a trunk (Trk1) on the user switches, and added ports 1 and 2 to the trunk. This was setup as one time as a basic Trunk and LACP trunk.
I still see all of the network traffic on the monitoring port.
Spanning Tree is enabled to try to prevent loops or broadcast storms.
This indicates to me that I clearly have not managed to make the switch aware that the two ports are associated.
How do I achieve what is listed in the diagram, please ?
