Problems with synchronization and clock recovery on Ethernet cause errors like... using old exam questions that are no longer relevant to practical networks.
Clock recovery was an important consideration is the very early days of Ethernet, when marginal 10 Mb/s PLL circuits could produce alignment errors. This is no longer an issue of any real significance; in particular, Fast and Gigabit Ethernet all use continuous-signaling systems, where clock recovery is not performed on a frame-by-frame basis.
-- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
