Optimize File Transfer on a 100Mbps LAN
Hi, I am using Windows XP on all my PC's. They are interconnected via
100Mbps Switch ports. These are normal Soho switches nothing fancy. I am trying to figure out how to get the most out of the LAN. Using Qcheck from Ixia I was able to tell that I am getting approx 94Mbps which I am extremely happy with. However while transferring files directly from 1 windows machine to the other using windows copy/ netbios I am seeing hardly 20 - 25 Mbps. That's a huge drop. I have set all my nic cards to auto detect. The reason being that most of these switches do not give me the ability to hardcode the speed and duplex. So they are set to auto-detect on their side and if I hardcode my PC nic's than I am basically seeing reduced performance. Hence all the PC's are set to auto detect. Can someone recommend any other settings (MTU, Window Size etc ???) that I should tweak or any other suggestions to get better performance. (Besides saying "Don't use Windows" :-) ). I have tried FTP and a large file transfer gives me only 30 - 40 Mbps. I want to get atleast close to 75Mbps. Is that even possible? Can someone please explain the concept of overhead and how this affects the transfer? Also how would window size come into affect. These are fairly new machines so I don't think the hardware on them should be the limiting factor. Even if the HDD is a normal 5400RPM drive shouldn't the performance still be atleast 50-60Mbps. Thanks
newbie123
newbie123:
Maybe the hard disks can't read faster than 25 Mbps?
Tomás Ó h=C
newbie123 wrote in part:
No, it is not. 10 Mbit/s is the only drop possible. The interface either runs at 10 or it runs at 100. It cannot run at 20 or any intermediate speed. You have 100 and a bottleneck elsewhere.
There is overhead in all transfers -- checking data for corruption and keeping track of packets. I'm doubt TCP receive window size [wiki't] would come into pure netbios.
That is very old. Modern drives should be at least 7200, and be capable of above that. However, writes are usually slower than reads, and OSes often make them much slower by metadata updates.
-- Robert
Robert Redelmeier
You mean a modern drive such as the Western Digital Cavier GP "1 Terabyte" drive, whose spindle speed is somewhere between
5400 and 7200 (WD won't say where) ?
it handly outperforming some 7200 rpm models, with over a gigabit per second sustained transfer rate.
The Cavier GP was released less than a year ago. Is that "very old"?
Walter Roberson
Walter Roberson wrote: (snip)
Higher speeds are mostly to reduce latency. For a given bit density it does also increase transfer rate. In most cases, transfer rate is out of the cache anyway.
The only way to reduce latency (rotational delay) is a faster rotation rate. There are other ways to increase the transfer rate if needed.
-- glen
glen herrmannsfeldt
In article , glen herrmannsfeldt wrote: [re: hard discs]
Increasing the bit density would allow reduction of the platter size, which would result in an average reduction in rotational latency. Using more physically smaller platters has the same effect.
Walter Roberson
Walter Roberson wrote in part:
No. Density and size are irrelevant. Spin rate matters: For a random seek (which first settles on the track), there's still on average one half a rotation before the desired sector comes under the read head. It doesn't matter how many sectors are on that track.
For track-to-track, the start of next track can be offset by the seek distance from the end of the previous track, cutting the rotational latency down to whatever jitter needs.
-- Robert
Robert Redelmeier
Hi All,
Thx for the replies. However I th> Walter Roberson wrote in part:
newbie123
There is one way to reduce latency without speeding up the disk, which is more than one head per track.
I believe the IBM 2305-1 did that. 2.5ms average latency.
-- glen
glen herrmannsfeldt
glen herrmannsfeldt wrote in part:
Certainly. Some extra trouble moving the longer arms and alignment problems from thermal expansion.
-- Robert
Robert Redelmeier
Well, if you think it is the MS-Win TCP/IP stack (and no reason it could not be), then find and run TTCP.EXE on both machines.
It is an old-time bandwidth utility that runs from memory, so disk speed and buffering isn't a variable.
I suspect Ixia Qcheck might have better buffering to improve disk performance.
-- Robert
Robert Redelmeier
The 2305 is a fixed head disk. The tracks may be wide enough not to worry about thermal expansion. Then again, they may specify the allowed temperature range. They were mostly used as a paging device for S/370.
-- glen
glen herrmannsfeldt
the modern fix would be use a "flash disk" - no seek time, and no rotational delay.
i saw a 1 or 2U server touted at IBC in Amsterdam last year which claimed up to a Terabyte of flash could be installed.....
stephen
Hi Robert,
I ran my tests using TTCP. Here's the results
C:\\>ttcp -t -l500000 10.10.1.10 ttcp-t: local 10.10.1.6 -> remote 10.10.1.10 ttcp-t: buflen=3D500000, nbuf=3D2048, align=3D16384/+0, port=3D5001 tcp ->=
10.10.1.1 0 ttcp-t: done sending, nbuf =3D -1 ttcp-t: 1024000000 bytes in 86994 real milliseconds =3D 11495 KB/sec ttcp-t: 2048 I/O calls, msec/call =3D 42, calls/sec =3D 23, bytes/call =3D 500000
Unless I am reading this wrong it seems to be telling me that I am transferring data at approx 91Mbps. Please correct me if I am wrong.
Any suggesti> newbie123 wrote in part:
newbie123
