Hi, I have a Cisco 3750 with layer 3 switching for the VLANs working fine. I have added a Netgear smartswitch GS748T. I have created the VLANS on the Netgear switch; now I want to set up a trunk (DOT1Q) between the switches. I have the Cisco trunk set up, but I never did a Netgear trunk and am confused by the Web interface for trunking; firstly, should the ports in each VLAN be tagged or untagged. Secondly when setting up a trunk the netgear config screen has an "ID" column and "port numbers" - do I select and ID for each VLAN and tick the port that are in that VLAN? Is there a command line interface for the netgear or does it have to be accessed through the browser? TIA, Ned
- posted
16 years ago
