Ethernet LAN multiplex one ethernet cable into two?
please rate
this thread
Posted by james on December 13, 2008, 5:17 am
In situation where I have access to one ethernet cable between two end
points, is there a way to multiplex so it functions like two independent
(lower bandwidth) ethernet cables?
Perhaps some sort of multiplexer sitting at both end points, each with three
ethernet ports, one goes to the cable, two others are the virtual cable end
points.
Posted by Steinar Haug on December 13, 2008, 6:12 am
Not necessarily. You can buy physical cable splitters which enable you
to run two 10/100 Mbps Ethernet links (each link only needs two pairs)
on one regular four pair Ethernet cable. No switch, no power needed.
Caveats: Obviously will not work for GigE, which uses all four pairs.
May or may not work for 10/100 Mbps Ethernet, depending on distance,
cable quality etc.
Steinar Haug, Nethelp consulting, sthaug@nethelp.no
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
multiplex one ethernet cable into two? james 12-13-08
Related PostsForumDate
Linksys WGA54G unreachable via wireless once it has ethernet... Wireless Networking 2008-03-18
LF: Crossover Ethernet Cable 25 feet Ethernet LAN 2006-08-25
Ethernet cable not working, USB is working Cable Modems 2005-10-02
After all that - I just realized the Nintendo Wii doesn'... Wireless Networking 2012-01-13
Ethernet Cable Wireless Networking 2012-01-04
ethernet and AC in conduit Wireless Networking 2009-01-03
Ethernet cable tool Whats it called Ethernet LAN 2011-04-28
Can CAT6 Cable Share Phone/100Mbit Ethernet? TELECOM General Telecommunications Forum 2007-03-09
problem with ethernet cable Ethernet LAN 2010-10-23
Wifi horribly slow on MSI RG60G, very fast with an ethernet ... Wireless Networking 2007-01-07
Problem with ethernet cable Wireless Networking 2006-12-12
Putting a switch between router and cable modem Ethernet LAN 2009-08-17
USB to Ethernet Cable Wireless Networking 2006-03-06
wireless lan to ethernet adapter. Wireless Networking 2005-12-20
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Mac to VLAN mapping on Cisco switches Cisco Systems
Sality virus help how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?‏ Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
