Multiple LANs - One Internet Connection
Any suggestions on how to connect multiple LANs to one cable modem Internet connection? Each LAN has 4 PCs (max) must remain isolated from the other LANs. One LAN requires the ability to limit what PC's can connect to the Internet.
gregorre8
Copy and paste into notepad.
--------- | Cable | | Modem | --------- | | | | | 192.168.100.0 /24 __________| |______ |__________________ | | | | | | |
Wayne
There are two 192.168.100/24 nets, which is probably not a good idea.
Best is to randomly assign the third octet of a 192.168 address, or the second and third of a 10.x.y/24 address. If you join a VPN it reduces the change of having to change all the addresses.
Otherwise, yes, this is probably the best, and with routers down to $10, a very affordable solution.
-- glen
-- glen
glen herrmannsfeldt
Actually yeah, that's not a good idea. Typo on my part!
Yeah, we could get into something like a PIX 515 with a VLAN-capable switch, but that would be expensive and unnecessary.
Wayne
You could roll your own with a spare PC and a few NIC cards, using freebsd or linux.. any old pentium box would work, or you could use one of the soekris boards..
I have a setup similar to this, with 3 lans, and a dsl line.. mapping to
3 static addresses on the dsl side, using freebsd, ipfw, and natd.
Bob Vaughan
gregorre8 wrote in part:
You've received good replies about hierarchy. I'd be more worried about performance. One person with a virus, p2p or sending large emails can use all the upstream bandwidth, making the large downstream unusable. A more intelligent [Linux] router can reduce this effect by QoS and throttling.
-- Robert
Robert Redelmeier
For the LAN routers, I planned on using DHCP but turn off NAT. For the LAN router, just the opposite. Good idea?
gregorre8 via HWKB.com
I have heard there is a version of linux to run on the WRT54G if you don't like the system that it comes with.
-- glen
glen herrmannsfeldt
You heard correctly. Sort of. Apparently you can hack it up through v4. V5 you can't. But what they did was come up with a special version (suffix L?) which can be hacked.
Google WRT54G hack and you'll get lots of links.
DLR
