Hello,
According to 'The All-New Switch Book', only a single 802.3ad aggregated link is possible between a pair of devices. *
Can someone please shed light on why this is?
My read (skim) of 802.3 suggests that so long as devices choose different operational keys for each aggregation, then there should be no reason multiple links don't work. The relevant sections seem to be
43.3.6.1 and 43.6.1.Maybe there's another way. I'm using Cisco products, and have the following goals:
- 2 aggregated links, each one is tagged, and they're carrying different VLANs so that unrelated applications can't impact each other's available bandwidth.
- I want to use LACP because PAGP doesn't support standby links. A standby link is important to me so that loss of a single link doesn't diminish the available throughput, and also doesn't cause unpredictable redistribution of traffic when the link count changes.
If I had to, I could run one aggregation with PAGP and one with LACP, because only one of the aggregations really requires a consistent link count.
Thanks!
/chris
- note that I haven't actually /tried/ configuring the aggregations. The network exists only on a whiteboard right now.
