Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Phil Schuman on March 17, 2005, 12:19 am
Please log in for more thread options A friend with a small biz called and asked me a question about how he can increase bandwidth by adding a 2nd DSL line. He has a single DSL line, with a wireless router for laptops, and a 24-port switch for the office hardwired desktops. He wants to increase bandwidth by adding a 2nd DSL line, along with a 2nd wireless router. Now - the question - how to setup the infrastructure - Each wireless router will have a different SSID - so that is ok - BUT - how to handle the IP addressing between the 2 DSL routers... THINKING - split the single wireless router subnet, into two wireless router subnets - 192.168.10.x and 192.168.20.x HOWEVER - Can they both co-exist on the same Ethernet physical network and go thru the same Ethernet switch ? Each PC/laptop GW will point to each subnet's router, so that should be ok - But - since they are on the same "physical network" if I wanted to talk from a PC or laptop on .10 to a printer on .20 will ARP's from the .20 have been recorded by the .10 PC, or am I always forced to go to the GW router for resolution. And, if I go to the router, will they have "seen" each others address, or will I need to manually add a static address for each other's subnet ? tnx for the discussion, comments, education - DSL line #1 DSL line #2 DSL modem #1 DSL modem #2 Wireless router (.10.1) Wireless router (.20.1) | | |----------->>> single switch <<<<---------|
| 192.168.10.100 192.168.20.100 192.168.10.101 192.168.20.101 GW = 192.168.10.1 GW = 192.168.20.1 | ||||||||||||||||
Posted by J. Clarke on March 16, 2005, 7:46 pm
Please log in for more thread options Phil Schuman wrote: > A friend with a small biz called and asked me a question
> about how he can increase bandwidth by adding a 2nd DSL line. > > He has a single DSL line, with a wireless router for laptops, > and a 24-port switch for the office hardwired desktops. > He wants to increase bandwidth by adding a 2nd DSL line, > along with a 2nd wireless router. Froogle "load balancing router". It sounds like you're drastically overcomplicating something that should be fairly simple to do. > Now - the question - how to setup the infrastructure -
> > Each wireless router will have a different SSID - so that is ok - > BUT - how to handle the IP addressing between the 2 DSL routers... > THINKING - split the single wireless router subnet, > into two wireless router subnets - 192.168.10.x and 192.168.20.x > > HOWEVER - > Can they both co-exist on the same Ethernet physical network > and go thru the same Ethernet switch ? > > Each PC/laptop GW will point to each subnet's router, > so that should be ok - > > But - since they are on the same "physical network" > if I wanted to talk from a PC or laptop on .10 to a printer on .20 > will ARP's from the .20 have been recorded by the .10 PC, > or am I always forced to go to the GW router for resolution. > And, if I go to the router, will they have "seen" each others address, > or will I need to manually add a static address for each other's subnet > ? > > tnx for the discussion, comments, education - > > > DSL line #1 DSL line #2 > DSL modem #1 DSL modem #2 > Wireless router (.10.1) Wireless router (.20.1) > | > | > |----------->>> single switch <<<<---------|
> | > 192.168.10.100 192.168.20.100 > 192.168.10.101 192.168.20.101 > GW = 192.168.10.1 GW = 192.168.20.1 -- --John to email, dial "usenet" and validate (was jclarke at eye bee em dot net) | ||||||||||||||||
Posted by David H. Lipman on March 17, 2005, 1:07 am
| A friend with a small biz called and asked me a question | about how he can increase bandwidth by adding a 2nd DSL line. | | He has a single DSL line, with a wireless router for laptops, | and a 24-port switch for the office hardwired desktops. | He wants to increase bandwidth by adding a 2nd DSL line, | along with a 2nd wireless router. | | Now - the question - how to setup the infrastructure - | | Each wireless router will have a different SSID - so that is ok - | BUT - how to handle the IP addressing between the 2 DSL routers... | THINKING - split the single wireless router subnet, | into two wireless router subnets - 192.168.10.x and 192.168.20.x | | HOWEVER - | Can they both co-exist on the same Ethernet physical network | and go thru the same Ethernet switch ? | | Each PC/laptop GW will point to each subnet's router, | so that should be ok - | | But - since they are on the same "physical network" | if I wanted to talk from a PC or laptop on .10 to a printer on .20 | will ARP's from the .20 have been recorded by the .10 PC, | or am I always forced to go to the GW router for resolution. | And, if I go to the router, will they have "seen" each others address, | or will I need to manually add a static address for each other's subnet | ? | | tnx for the discussion, comments, education - | | DSL line #1 DSL line #2 | DSL modem #1 DSL modem #2 | Wireless router (.10.1) Wireless router (.20.1) |>
| 192.168.10.101 192.168.20.101 | GW = 192.168.10.1 GW = 192.168.20.1 | Your friend needs to double the DSL bandwidth and not get two DSL lines and really should be SDSL rather than ADSL which he probably has. He will not double his bandwidth effectively with two xDSL lines and two wireless Routers. If the person really wants to xDSL lines tthen what is really needed is a Load Balanced Router that has two WAN ports such as the Edimax PermaLink PRI-682 http://www.edimax.com/html/english/products/PRI682.htm -- Dave | ||||||||||||||||
Posted by Phil Schuman on March 18, 2005, 4:29 pm
tnx for the comments about a dual port WAN router... We'll have to look into those, but then how is the price, and does each WAN port directly support DSL/PPPoE, etc ? Here was another network design that I thought off.... Instead of having 2 subnets, and then having to setup a route between them, why not just keep ONE subnet, as the problem is just with the GW address to force 1/2 the traffic to each DSL line.... yeah, not load balanced, but cheap :) I wonder if this will work.... 192.168.1.xxx 255.255.255.0 Take each router, and setup it's DHCP with a limited number of addresses (1/2 of the total), and with a unique range .100-.110 and .200-.210, but on the same subnet. Then, both will reply to any subnet DHCP request, and maybe 1/2 will be satisfied by each router. If not, then at least a stop-gap measure will be that each router will only serve up 1/2 of the PC's used. So, if say 20 PC's all try to get DHCP served, then 10 should be "forced" to each router by the limited DHCP reply and it's associated DHCP info (address, DNS, GW address). thoughts ? | ||||||||||||||||
Posted by J. Clarke on March 18, 2005, 2:23 pm
Phil Schuman wrote: > tnx for the comments about a dual port WAN router...
> We'll have to look into those, but then how is the price, $150 and up. > and does each WAN port directly support DSL/PPPoE, etc ?
Yes. They're designed specifically for that purpose. > Here was another network design that I thought off....
> > Instead of having 2 subnets, and then having to setup a route between > them, > why not just keep ONE subnet, as the problem is just with the GW address > to force 1/2 the traffic to each DSL line.... yeah, not load balanced, > but cheap :) > I wonder if this will work.... 192.168.1.xxx 255.255.255.0 > Take each router, and setup it's DHCP with a limited number of addresses > (1/2 of the total), and with a unique range .100-.110 and .200-.210, but > on the same subnet. Then, both will reply to any subnet DHCP request, > and maybe 1/2 will be satisfied by each router. If not, then at least a > stop-gap measure will be that each router will only serve up 1/2 of the > PC's used. So, if say 20 PC's all try to get DHCP served, then 10 should > be "forced" to each router by the limited DHCP reply and it's associated > DHCP info (address, DNS, GW address). > thoughts ? That's not going to force traffic to either line, it's just going to give you messy DHCP. to make it work, you will probably need to lock IP addresses to MAC addresses, which pretty much defeats the purpose of DHCP. -- --John to email, dial "usenet" and validate (was jclarke at eye bee em dot net) | ||||||||||||||||
| Similar Threads | Posted |
| multiple DSL lines for single infrastructure | March 17, 2005, 12:19 am |
| Multiple VLANs on Single NIC | January 19, 2006, 8:06 am |
| Multiple PHYs to a single MAC | April 11, 2007, 10:30 am |
| multiple vlans at a single port | June 23, 2008, 1:13 am |
| Phone lines to 10/100 | July 27, 2004, 4:26 pm |
| Ethernet over single UTP | April 19, 2005, 4:32 pm |
| Ethernet over power lines. Are there any gotchas? | December 19, 2006, 6:01 pm |
| 1000BaseSX and Single Mode Fibre | April 8, 2005, 12:15 pm |
| Ordered 5 single board computer ref. design, all are same MAC addr, what to do? | February 14, 2006, 11:24 pm |
| Complete hangup of network caused by single device | September 8, 2006, 5:01 am |
| 802.3ad and multiple mac addresses | June 4, 2007, 2:25 pm |
| Why multiple filtering databases in 802.1q? | December 16, 2004, 3:23 pm |
| Multiple T1 transmissions on Cat5E | August 8, 2005, 9:45 am |
| Systems can be 1-3 kms apart; 1 or multiple LANs? | April 2, 2007, 7:16 am |
| multiple MACs on a port | April 27, 2007, 7:53 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
