Hello
If i set the default vlan id of a l2 switch to 1
then is it possible that i set the Multicast VLAn ID of the same switch to some another value
foe exp -- 4 or 5 or any vlan except 1.
Thanks
Vikrant
Hello
Thanks
Vikrant
Yes, and if you are using multicast vlans then you would normally set the multicast vlan to something other than the switch default vlan.
Note: multicast vlans are an extended feature that are not required to be implemented even on switches that implement multicast.
Just to be sure where all these VLAN questions are leading, you do appreciate that you don't need either a "default VLAN" or a VLAN assigned to multicasts, or any other VLAN implementation, necessarily? Perhaps some switch vendors create a default VLAN by default. That doesn't mean that this is a requirement of Ethernet or any other L2 protocol I can think of.
None of the 802 or IP protocols require use of VLANs. VLANs are a neat trick that can be helpful in certain circumstances.
Bert
