May I use a Linksys WRT54G router as secondary wireless access point?
Threaded View
I have a DSL home ethernet LAN using one Linksys WRT54G router with
wireless features turned on, but the signal at the far end of the
apartment is dodgy for laptop use. I don't want to relocate the main
router, but have the opportunity to get a second WRT54G cheap. Can I
configure a second one as a slave (access point), and have wireless
connection served by either one of the devices? The two routers would not
communicate wirelessly, but by CAT5.
I realize that I need to turn off the DHCP server function on the "slave,"
is there anything else I need to do? Should each router be set to use a
different wireless channel, or the same one?
I assume that it would be okay to connect more devices/computers to the
second "slave" router via CAT5 as well; is that true?
Thanks very much,
Charles Wahl
<remove uppercase letters in email address>
Re: May I use a Linksys WRT54G router as secondary wireless access point?
Charles Wahl wrote:
That sounds fine to me.
Why not use DHCP on the second?  It does need to be a different
(sub)net, though.  I would probably static address the WAN port of
the second, but it could even be done through DHCP.
Yes, that should work fine.
By the way, these are more TCP/IP question and not ethernet
questions so should probably go to comp.protocols.tcp-ip
-- glen
Site Timeline
