Maximum Length for 1000Base-SX
Can I calculate the maximum run length for 1000Base-SX based on:
Max dB Loss (7.5dB) > # patch panels * loss per mated pair + distance attenuation
Where loss per mated pair is nominally < .75 dB, but we test for < .3 dB;
and distance attenuation is 3 db / km
And thus exceed 220 m over 62.5/125 =B5m?
Do I count the switch to patch cable as a mated pair, or is that included within the
How about modal dispersion? Is there a calculation for that?
Or do I have to run replacement 50 =B5m fiber?
TIA
Wrolf
Wrolf
How far do you want to go?
Bod43
the limit i learnt was 260m.
No - the limit isnt power loss, it is model dispersion (ie pulses go via different paths thru the cable and overlap).
So it actually depends on your m/mode cable type - higher bandwidth / distance product means you can stretch the limit.
1 easy way to get further is to use LX GBICs and mode conditioning patch leads - that gives you 550m (the same as 50 um fibre).
Any more than that then you need a switch at an intermediate point, single mode - or you just "wing" it and hope there is enough slack in the spec for your install that it works.
FWIW i have seen 1200m work on old 50 u cable (over a decade ago now, when we put the 1st Bay Networks layer 3 switches in - we didnt have the extra slot for the single mode card).
stephen
Turns out one run is 1500', with a single SC-SC patch panel at each end.
The other run is about 2000', with a single SC-SC patch panel at each end, and a pair of SC-SC panels in the middle. The patch panels will all be tested for maximum 0.3dB loss per mated pair.
Wrolf
Wrolf
