Ethernet LAN maximum copy size
Subject Author Date
maximum copy size *selah* 11-15-05
Posted by *selah* on November 15, 2005, 5:43 pm
I've been trying to copy an 8meg folder from one computer to another on
an ethernet connection. I'm unable to copy it all at once. I assume that
there's some size limit.
Was wondering what the size limit is or if there's some way to copy the
whole folder at once? We're using win98 and transferring from a thinkpad
(laptop) to a dell pentiumII tower.
Posted by Walter Roberson on November 15, 2005, 10:16 pm
:I've been trying to copy an 8meg folder from one computer to another on
:an ethernet connection. I'm unable to copy it all at once. I assume that
:there's some size limit.
There is no inherent file transfer size limit in ethernet, tcp, or udp.
:Was wondering what the size limit is or if there's some way to copy the
:whole folder at once? We're using win98 and transferring from a thinkpad
:(laptop) to a dell pentiumII tower.
I would suggest you check with one of the windows newsgroups; the
problem is at the Windows layer.
Programming is what happens while you're busy making other plans.
Posted by chimique on November 29, 2005, 12:09 pm
What is SOCKS proxy server?
SOCKS is a networking proxy protocol that enables hosts on one side of
a SOCKS server to gain full access to hosts on the other side of the
SOCKS server without requiring direct IP-reachability. SOCKS is often
used as a network firewall, redirecting connection requests from hosts
on opposite sides of a SOCKS server. The SOCKS server authenticates
and authorizes requests, establishes a proxy connection, and relays
data between hosts.
http://www.checkproxy.net
Similar ThreadsPosted
maximum copy size November 15, 2005, 5:43 pm
Maximum size of Ethernet frame November 11, 2004, 9:40 am
Maximum maximum packets per second on 10 megabit ethernet ? 1.250.000 / 1538 = 812,743823 ??? February 19, 2005, 11:31 am
LLC maximum transmit value November 30, 2004, 11:30 am
Maximum MAC multicast filters? October 5, 2005, 8:48 am
Maximum Length for 1000Base-SX September 14, 2006, 6:10 pm
Maximum number of stations on IEEE 802.3 networks December 7, 2006, 5:25 am
Maximum Cat5e or Cat6 Cable Length February 16, 2007, 3:48 pm
how much size is enough ? May 25, 2006, 6:45 pm
MII preamble size February 14, 2008, 12:46 pm
Ethernet Frame size January 17, 2005, 8:01 pm
Maximum Auto-Negotiation Time on Twisted-Pair Gigabit Ethernet June 19, 2008, 8:21 am
Seen any cigarretpack-size 4-ports switch? February 8, 2006, 2:14 pm
Help - how to adjust capture buffer size of Ethereal? October 1, 2004, 12:00 am
Cigarette Pack Size Ethernet Bridges? September 13, 2006, 2:45 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
