Hello,
Allow me to get some information out of the way before my problem description.
PC1 - Running Fedora Core 3, ethtool version 1.8 (reported from man page), Intel 82540EM NIC. PC2 - Windows XP acting as a server for file transfers Switch - 4 port supporting auto-negotiation
During these tests I am download a 50MB file onto PC1 from PC2 and changing the link speed of PC1 during the file transfer with ethtool.
My Problem:
I am using ethtool to change the linkrate of a NIC for a project at my university. I have run into a problem though: when changing the the link speed with ethtool the link goes down for approximately 4 seconds. The commands I am using are:
First: ethtool -s eth0 autoneg off duplex half speed 100
Later: ethtool -s eth0 speed 10 ethtool -s eth0 speed 100
I am toggling between the two speeds throughout my test. Each time the link goes down for approximately 4 seconds. I have done over 50 ethereal traces to verify this standard 4 second delay. I am not speaking just of TCP, there are no packets on the link for 4 seconds.
However when I use the command:
time { ethtool -s eth0 speed 10; }
I get the real time around 0.100 seconds each time. To me this shows that ethtool is returning from executing quickly and would not be the cause of the link down time. To verify this I tried physically unplugging the link for fixed period of time and then plugging it back in. When doing this the link is always down for 3 seconds longer than it is unplugged.
Detection portion of Auto-Negotation. I have been unable to find the length of time Auto-Negotiation waits before deciding there are no FLPs from the other link partner. I find it hard to believe that this is the cause of the delay, but could it be?
Any suggestions or advice for helping me track down the cause of this delay?
Thank you for your time,
-Matt
