Thanks for your replies, it was very important to hear these things from you. I will just briefly summarize all the threats that you all have addressed and some that I add. I ask you once again to comment on these, since all these comments were extremely useful. I will have some references to my first post.
I will have to use gigabit swtiches between main floor switches (MFSs), since other kinds would be easily saturated by the possible load. The building has some cabling, it needs to be tested and some (or all) of the cables surely must be replaced. PCs are not my concern - I am here just to build the network. Thus, security is not my primary concern. In order of importance, these are the risks:
- Feasibility - It is very important that any kind of network is built,
- Downtime - It should work most of the time, but it is not a problem if it breaks even for a whole day. Naturally, the network should be built to avoid these problems. Downtime due to overload is not a problem, since the users will be warned about the network capacity. I am thinking about making some restrictions about the load each of the computers can impose to the network. However, this is probably not possible with switches only,
- Cost - I count at around $10k for cables, switches and routers. Computers exist already,
- Security - I don't take this too important. The users will be responsible, since the network will not be in my control. Each user will be able to setup the computer as (s)he wants. They will be warned about such possibilities (e.g. virues),
- Scalability - Absolutely not important. The network should work with current capacities and it is not important to extend it. Of course, I will not miss the opportunity to make it extensible, but if that would increase any other risk, it's out of the question.
Considering this, do you agree with the above comments? Also, are they feasible with switches only? Routers are probably too expensive to put one per floor. Maybe a few routers will be enough. Do you think that using routers to control the network is a better solution then using (un)managed switches?
About the comment that "peer-to-peer file sharing ... is going to be chaotic at best" and the next comment that I need a Windows server... It will probably happen - a dedicated server to manage the needs of this network only. That is, WWW server and DNS server at least. Do you think putting a DNS will solve this problem? DHCP is not important right now, but it could be activated later. All users will be instructed to statically bind their computers to the specific address. I will do the first-time configuration of all computers, so this will probably not be the problem. The computers should not be floor-isolated, i.e. peer-to-peer file sharing should work accross the whole building. Printing is not important (i.e. if bad, then we won't do it).
No "transient devices", like laptops or such are planned. The network is a cable-only variant. As I mentioned, scalability the last problem I will address. The wiring is totaly feasible, I have explicit contract with the owner of the building to do what I need. "You want as few layers of devices as practical" - I know that this is true, but the structure of the building makes it easier to do it 3-5 switches per floor, 1-3 main floor GBE switches. How much will this impact the performance? Virus-checks, e-mails, auto-updates and such are not counted in - i.e. I will not put such servers. WWW is probably the only user-friendly server I will possibly put. E-mails are very unimportant in this setting, because of the current (and free) in-building telephone lines.
Internet connection should be "meaty", but as I mentioned better anything than nothing. I consider that router can be configured to somehow restrict the access to the users that overload the network and/or Internet connection too much. If not, then at least a some software can be installed on the computer to do that. What do you think about this?
Does anybody have some practical info about this? Anybody that fits in this situation (considering all the above metioned things, especially $)? The practical info would be very appreciated, because that is what I mostly lack about the networks of this size.
At the end, thanks again for all your comments!
