Hi All: I have a VRRP question for all network experts out there. What happens when a port which is a member of a Vlan goes down in a VRRP environment? Diagram is as follow:
____________________ | | Vlan2 | |port 3 VRRP |port 3 Router1------------Router2 |port 2 |port 2 | | |Vlan1+Vlan2_______|
Router1 is master for all vlans Router2 is slave for all vlans Vlan2 and Vlan3 are configured as two different class C IP subnets with different default gateways. Vlan 2 is configured on both port 2 and port 3 on router1 Port 2 is a vlan trunk which includes vlan1 and vlan2 What happens when port 3 on router1 goes down. -Router2 will assume the mastership becomes the default gateway for Vlan2 -What happens to the gateway of Vlan2 on port 2 of router1 Will it continue to use port 2 of router1 as gateway or it switches to Router2 Thank you for any insight that you can provide.
-Tudalat
