Our ISP is going to provide us with the following over one physical ethernet wire:
- Internet access on VLAN 3854
- Private network to our branch location on VLAN 1024
I have a HP Procurve 2824 switch which we're using for gigabit connections between our servers.
How do I configure the 2824 switch to take the connection from our ISP and send the Internet connection to our firewall and the private network connection to another one of our switches?
On the switch, under VLAN configuration there is a DEFAULT_VLAN (primary) with VLAN ID 1. I've added two more: Internet (VLAN ID 3854) and Private (VLAN ID 1024).
I then Tagged port 2 (which is what I connected the Ethernet wire from our ISP into) for both VLAN IDs 3854 and 1024. I also tagged port 3 with VLAN ID 3854 and connected a wire from that port into our firewall. Lastly I tagged port 4 with VLAN ID 1024 and connected that to a computer with a static IP.
I was hoping that would work but it doesn't. Can anyone give me some guidance? Thanks.
