About 18 months ago we upgraded all of our key servers to use fiber optic gigabit ethernet cards. We went with Compaq NC6136 cards attached to an Extreme Networks Summit 48 gigabit ethernet switch, and several servers are attached to Cisco 2948 switches with gigabit ethernet modules added. To my horror, in chasing down some other network issue, I have seen today on a sniffer that every one of the machines with these cards is giving repeated checksum errors on TCP connections. I verified carefully that the only interfaces giving checksum errors are the gigE cards, and all of our 100 megabit over copper interfaces are working perfectly.
Is there some trick to configuring settings on a gigabit ethernet card under Windows 2000, or alternately to making these cards work with a fiber optic card on an ethernet switch? I had thought that this would be a pure plug and play operation, and that fiber optic gigE would reduce latency at very least. A few bad connections I could possibly believe might be caused by dirty fiber cables, but because every one of six interfaces is exhibiting the same defect, I am more inclined to believe that we have messed up on some configuration issue for the cards under Windows 2000, or alternately some settings on the switch.
Any advice on what might be causing these checksum errors is appreciated.
