Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Bipin on October 11, 2006, 4:45 am
Please log in for more thread options hai all, i am working in a network having morethan 200 windows XP sysetm,our network uses CISCO switch and router. we have a remote site which connected trhough 4MBps MAN conectivity through one off services provides frame relay.We need to connect our remote site alltime coz, our file servers are in remote site. some time we feel our network soo slow , even it took morethan 2 min to open a 1 mb .doc file . 1,How can i rectify this issue 2,How can i check file transering speed ( any software can use for this??) 3.How it possible to check how many bandwidth is used by each off computers i hertlly requesting all to help me for solving this problem . | |||||||||||||||||||||||||
Posted by Al Dykes on October 11, 2006, 8:57 am
Please log in for more thread options Every version of Windows since NT3.5 has a tool called Perfmon.exe. It can monitor and count the usage of just about every aspect of the computer's operation. It can remotely monitor other windows boxes. Your Cisco switch and router probably have network management capability which can got you usage figures for the pipe. Various versions of netmon, a network monitering tool, are included with the different versions of Windows Server. If your servers are *nix-based, there are lots of monitoring tools available to you. -- a d y k e s @ p a n i x . c o m Harrison for Congress in NY 13CD www.harrison06.com Don't blame me. I voted for Gore. A Proud signature since 2001 | |||||||||||||||||||||||||
Posted by Robert Redelmeier on October 11, 2006, 10:22 am
> use for this??) I use `ttcp` to test network speed. It avoids the disk and occasionally software bottlenecks. It measures OS & hardware. By running it as UDP, I can get an idea if TCP is mistuned. But you need access from both ends. When you can't (usually across the Internet), then hit some reliable site and see what kind of ftp throughput you get. > 3.How it possible to check how many bandwidth is used by
> each off computers Usually by using a sniffer such as `tcpdump` or monitoring areas on a managed switch. -- Robert | |||||||||||||||||||||||||
Posted by Rick Jones on October 11, 2006, 1:28 pm
>> use for this??) > I use `ttcp` to test network speed. It avoids the disk and
> occasionally software bottlenecks. It measures OS & hardware. By > running it as UDP, I can get an idea if TCP is mistuned. But you > need access from both ends. When you can't (usually across the > Internet), then hit some reliable site and see what kind of ftp > throughput you get. ttcp would be ok if the file transfer mechanism is FTP. If it is SMB, (or NFS) then a request/response test would be a better match - say a netperf TCP_RR test with suitable request/response sizes to match what SMB is doing. Be very cautious about UDP bulk transfer benchmarks (ttcp, netperf UDP_STREAM). They often have no end-to-end flow control and as such may completely saturate a bottleneck link, much to the chagrin of other users. When diagnosing "performance issues" I often start by looking for retransmissions. Especially for request/response sorts of applications, even a single lost TCP segment can ruin the whole thing. So, check things like netstat statistics, or its platform equivalent. If you can also check link-level statistics and statistics at the switch(es) and/or the devices joining your LAN's to the MAN. rick jones -- Process shall set you free from the need for rational thought. these opinions are mine, all mine; HP might not want them anyway... :) feel free to post, OR email to rick.jones2 in hp.com but NOT BOTH... | |||||||||||||||||||||||||
Posted by Robert Redelmeier on October 11, 2006, 1:38 pm
>> occasionally software bottlenecks. It measures OS & hardware. By >> running it as UDP, I can get an idea if TCP is mistuned. But you >> need access from both ends. When you can't (usually across the >> Internet), then hit some reliable site and see what kind of ftp >> throughput you get. >
> ttcp would be ok if the file transfer mechanism is FTP. > If it is SMB, (or NFS) then a request/response test would > be a better match - say a netperf TCP_RR test with suitable > request/response sizes to match what SMB is doing. Agreed. Even the venerable ping can be very useful. > Be very cautious about UDP bulk transfer benchmarks (ttcp,
> netperf UDP_STREAM). They often have no end-to-end flow > control and as such may completely saturate a bottleneck > link, much to the chagrin of other users. Isn't that the idea :) but a wise precaution to limit testing, especially test uninterrupted duration. > When diagnosing "performance issues" I often start by looking
> for retransmissions. Especially for request/response sorts > of applications, even a single lost TCP segment can ruin the > whole thing. So, check things like netstat statistics, or > its platform equivalent. If you can also check link-level > statistics and statistics at the switch(es) and/or the > devices joining your LAN's to the MAN. Always a good idea. Bad/marginal cabling can easily cause bit errors that usually result in retransmits. -- Robert | |||||||||||||||||||||||||
file transfer speed in a network
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>this??)
>computers
