Ethernet LAN ethernet frequency and power on ethernet
Subject Author Date
ethernet frequency and power on ethernet praveen 10-25-04
Posted by praveen on October 25, 2004, 4:04 am
Hello,
I am want know the frequency of the ethernet data so that i can decide
on the value of the inductor through which i can feed DC power.
I have heard the ethernet can range from DC to 10 Mhz (10TBase), in
this case i cannot feed power on ethernet. Yes i know about power on
ethernet but the power i want to transfer is 60 W, so i feed the power
directly to the line
I need what is value of the inductor i have to choose.
Waiting for reply
Regards
Praveen
Posted by on October 25, 2004, 11:11 am
I'm not sure you can, and still be legal. The ampacity of the wire is
going to limit your current, the various codes for low-voltage wiring
are going to limit your voltage, and the intersection of the two is
going to give you your maximum power (minus line losses). 802.3af
peaks out at about 20 watts input to the cable (15.4W per device),
though you might be able to cheat and use all four pairs to double
your power. The standards are a nightmare to parse, but it might be
possible. Dunno what standards you have in India, or if this is for
commercial operation or not. Can you pull another cable?
Posted by glen herrmannsfeldt on October 26, 2004, 7:18 am
If it is 15W per pair then he should be able to get close
to 60W with four pair. (If it is limited by cable heating
then it will be a little less.)
I would have tried center tapped transformers before
using inductors to isolate it.
It is supposed to be that three phase AC makes the most
efficient use of its wires, so three phase between three
pairs might do it. That is, if you are limited by average
current squared and peak to peak voltage. It shouldn't
be much harder to keep 60Hz away from ethernet, though
it could run at a higher frequency if you have to generate
it anyway.
-- glen
Posted by on October 26, 2004, 2:46 pm
>> your power.
It's actually pairs of pairs, so he could double the power. Google
for the PoE spec...
Posted by Walter Roberson on October 25, 2004, 11:29 am
:I am want know the frequency of the ethernet data so that i can decide
:on the value of the inductor through which i can feed DC power.
:I have heard the ethernet can range from DC to 10 Mhz (10TBase), in
:this case i cannot feed power on ethernet.
I don't know about DC, and I don't recall the details about 10BaseT,
but at the higher bit rates, the frequency is not just
1/(megabits per second): instead, they use a slower carrier and
more bits per symbol. Some error correction is used, so the raw
number of data points sampled exceeds the nominal bandwidth.
10/100/1000 BaseT are all async, so when there is no data going through,
there are no pulses on the line. I never looked deeply enough to
find out whether it uses a DC carrier or if the line floats free.
If you are using 10BaseT, then several of the wires on a typical
Cat5 8-wire RJ45 setup are not used at all (not even as grounds):
if you need to carry power, could you perhaps use those wires?
This might not help if you are running Cat3 instead of Cat5.
Can a statement be self-referential without knowing it?
Similar ThreadsPosted
ethernet frequency and power on ethernet October 25, 2004, 4:04 am
Power Over Ethernet December 15, 2005, 12:03 am
Power over ethernet August 15, 2006, 7:13 pm
Power Over Ethernet (PoE) implementation June 21, 2005, 4:13 am
Power over Ethernet Environmental Requirements June 28, 2005, 3:20 am
Ethernet over power lines. Are there any gotchas? December 19, 2006, 6:01 pm
Industrial Power Over Ethernet (PoE) Switch by GarrettCom, Inc. May 31, 2005, 7:02 pm
sending high frequency in phone line November 8, 2004, 5:27 am
BEFSR41 led behaviour on power-up August 28, 2004, 10:39 pm
How to clean up mains power? August 10, 2007, 4:19 am
The best distance covered by a transmit power booster Linksys WRT54g October 9, 2004, 4:14 pm
USB Ethernet controllers that use the ASIX AX88772 or AX88172 USB-Ethernet bridge devices August 19, 2005, 7:04 pm
Wither simple ethernet-ethernet routers? October 18, 2004, 11:06 pm
Difference between Ethernet 2 and 802.3 Frame per the Ethernet FAQ July 28, 2006, 9:02 am
Ethernet over T1 (Ethernet over WAN...) October 17, 2004, 4:15 am
