Hi All,
I want some guidence for encoding schemes used in ethernet
I know that for gigabit ethernet mostly the 8b10b encoding scheme is used and also I have heard about 64b/66b scheme.
which one is actually used....?
If I need to send my data on ethernet which one I should use and while receiving any data, is there any method for detecting that the receiving data is coded in which scheme...?
Thanks & Regards Kedar
