Hi All,
I have a large network between 2 sister businesses that are located next to each other. We are connected together with a fiber connection to share resources and costs. We have seperate routers and DHCP servers
with different firewall rules. The problem we are having is that when a
DHCP client plugs into the network it is a toss up as to which DHCP server will answer the clients request the fastest. I have a HP procurve 4000m switch. Is there any way to configure my Fiber port to not pass DHCP no matter which way it is coming from. This would solve our problem but I have been unable to find a way to make it work.
Our addressing is 192.168.0.1 thru 192.168.3.255 . Business A uses
192.168.0.1-192.168.1.255 and Business B uses 192.168.2.1 through 192.168.3.255. But there is some spill over with old machines (old servers that there IP's are not easily changed) in each others address space and shared machines (Plptters, Heavy Machinery) that both companies need to be able to access So we need the 255.255.252.0 Subnetmask to stay. We also do not have any type of spare router laying around.
Thanks
Dan
