I have this good rx frame below. I am using easics crc generator tool to get 32 bit crc, with 32 bit data. I am unable to produce the crc that has been received in the packet which is e5 5c 0b f8 (from the packet below) I am must be missing something. Below is the function generated by easics tool. I have a good frame below with good crc. When I call the function, the first byte I send is in the order first bytes sent is bit reversed in each byte
// crc_packet[*] are the bit reverse of the data in the packet
next_crc
