Hi, I purchased a new Airlink router to replace my old Linksys router. Airlink is connected to the cable modem. I connected the uplink of the old linkysy router to one of the ports on the back of Airlink. I did not make any changes to the Linksys other than changing the DCHP IP address range for the Linksys. Now the computers on my ne Airlink have
192.168.1.xxx and the ones connected to Linksys have 192.178.1.xxx.Here is the problem, All machines can obtain DHCP address from the router they are hooked up to. All machines can access internet. But when I try to map a drive from machine on Airlink Router to a machine on Linksys router I can only use the IP address of the machine. Machine name does not work mapping from one subnet to the other. Any ideas?
Thanks,
