I was wandering if someone could help me..
I have a home network setup that includes two US robotics Gigabit switches a 16 Port Swithch (USR 997932A) and an 8 port (USR 997933).. I am trying to connect these two switches together using a standard (working) cat 5e cable without any success.
If i connect a server to the 16 port switch and then connect a pc to the 8 port switch and try to ping the server it fails... however if I connect the pc to the same 16 port switch it all works fine... is there a problem with connecting two gigabit switches together?
Constants:-
- I have tested both switches independently and they work fine
- i have tested and replaced all cat 5e cables and again they are fine.
- The PC's have DLINK Gigabit NIC cards installed and these work fine.
Can anyone suggest why I might be having a problem?
regards Ajay
