Ethernet LAN cat5 cable length problem
please rate
this thread
Posted by on February 22, 2007, 9:04 am
hi, im trying to run an internet connection into our mess room at work
which is about 25 meters away from the office where the computers and
modem etc are. in the office the modem is connected to a router then
in to a switch to feed the several computers, i have connected a short
patch cable from a spare socket on the switch to my laptop and all is
fine, but when i run a length (about 25 meters) of cable down to the
mess room it will not connect(starts to aquire a netwok address then
stops and starts again repeatedly), is the length of the cable the
problem and if so is there anyway round it, the cable is the copper
core (solid) type cat5 cable.
Posted by Kay Archer on February 22, 2007, 9:14 am
Cat5 (if properly configured and installed) should be good up to 100 metres.
no sharp bends in the cable, correct tool used, only the allowed amount
stripped or untwisted, etc.
See http://en.wikipedia.org/wiki/Category_5_cable  ,
http://grouper.ieee.org/groups/802/3/tutorial/july98/kish_070798.pdf or
http://grouper.ieee.org/groups/802/3/tutorial/march98/mick_170398.pdf
Use punch down (110) jacks at each end and then (factory made) patch cables.
For cabling materials and tools, I've always had good luck with Milestek
(and I'm close enough that an order this afternoon will arrive tomorrow on
ups ground (g)).
Posted by on February 22, 2007, 11:25 am
Seehttp://en.wikipedia.org/wiki/Category_5_cable,http://grouper.ieee.org/groups/802/3/tutorial/july98/kish_070798.pdforhttp://grouper.ieee.org/groups/802/3/tutorial/march98/mick_170398.pdf
hi thanks for the reply, i know that it should be good for 100 meters,
but for some reason it isnt, i have tested the cable with a lan cable
tester and all is fine, so i made up another run of 25 meters an left
it coiled up by the side of me, just to check whether it was the other
cable, but still the same. would it make any difference that the cable
is coming out of a switch, as when i put an adapter on the end to
convert it to a crossover cable and link to pc's to gether its fine,
ive read that the max length for  patch leads is 10m does this affect
me at all?
cheers
Posted by Carl Navarro on February 22, 2007, 7:46 pm
No.
Let's see.  You're using 4 pair Cat-5e or higher rated cable, and it's
within the length limits.  HOW ARE YOU WIRING THE CABLE?
Did you punch the cable down on IDC jacks and use a patch cable?  Did
you crimp connectors on the ends of the solid wire?  Did you make the
pretty wires match some form of color code?
I'm guessing not.
Carl Navarro
Posted by Harald Andersen on February 23, 2007, 10:35 am
Snip...
Thats your problem ....
If you made a patch cable, using SOLID CORE,
your out of luck.... It is NOT meant to work !
/Hca
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
cat5 cable length problem wattywatts 02-22-07
Related PostsForumDate
Maximum cable length from bcm to digital handset Nortel Networks 2007-12-19
Ethernet linked access point appears sensitive to cable leng... Wireless Networking 2008-05-02
Extending USB cable with CAT5 cable adapters Wireless Networking 2009-08-14
C7200 => very long boot .... FastEthernet1/0 cable/connector... Cisco Systems 2009-01-12
XM10 X10 signal cable length General Home Automation 2008-07-03
Ethernet connection sensitive to cable length Ethernet LAN 2008-05-04
Running Cat5 cable outside Ethernet LAN 2007-03-10
DSC 864 Serial Cable Length CCTV, Alarms and other Physical Security 2006-04-28
Homemade cat5 cable using existing phone line fails. Digital Subscriber Line 2006-03-11
Maximum Cat5e or Cat6 Cable Length Ethernet LAN 2007-02-16
Can I use a CAT5 cable as a TV Coax cable? LAN and Telecom Cabling 2006-10-14
Best brand coax and F connector for HD cable? General Home Automation 2006-02-24
lengthening CAT5 cable LAN and Telecom Cabling 2005-11-03
Pretty much OT: Ordering CAT5 cable online Wireless Networking 2005-04-11
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Mac to VLAN mapping on Cisco switches Cisco Systems
Sality virus help how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?‏ Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
