Breaking of Ethernet Frames.
Hi All,
I am very new to the Ethernet area.
I am trying to design and Implement an Ethernet switch or Multiplexer.
so say if I am bridging between two 1-gbps channels with one 2-gbps channel. when I think of designing a TDM switch between the 2 channels of 1 gbps my basic design will contain a MAC and a FIFO right...?
I was thinking that if the incoming data frame is long so that it will cross the TDM slot for that channel of 1 gbps. then I will have to break that frame store the remaining data in fifo and send it in the next slot.
Here I am not getting is that how it will get reconstructed at the receiving end . So firstly is it allowed to break like this if yes then how to insert a packet number etc in the frame.
Please Help...
Thanks & Regards. Kedar
kedarpapte
Hello! I believe that break a frame ethernet is not allow. For example, at ip frames is allowed. bye.
ak0178
