BPSK
Threaded View
There is discussion in another newsgroup in whether
Manchester coding is, or is not, a form of BPSK.
I usually consider it as synchronous phase modulation
(the wikipedia page seems to use the work coherent where
I would use synchronous).
I thought I would ask here, as there doesn't seem to
be much else to ask here.
-- glen
Re: BPSK
On Wednesday, March 28, 2012 8:33:49 PM UTC-7, glen herrmannsfeldt wrote:
Yes, it is precisely BPSK. The "zero" symbol (half-period high, half-period low)
is a 180-degree phase shift of the "one" symbol (half-period low, half-period
high).
Sorry for the long latency on response, I don't check this group (or any of the
old Usenet groups) very often. Usenet has passed into history, for the most part.
Rich Seifert              Networks and Communications Consulting
                                 21885 Bear Creek Way
(408) 395-5700        Los Gatos, CA 95033
(408) 228-0803 FAX
Send replies to: usenet at richseifert dot com
Re: BPSK
(snip, I wrote)
It seems that signal processing people disagree, though I
am not sure why.
Sorry for the slow reply. It seems that the server that I posted
from doesn't get incoming posts. I switched servers temporarily,
and notice that there was a reply.
Thanks,
-- glen
Re: BPSK
Except that Manchester is not modulating an RF carrier. My view is that the two
are related, but Manchester is baseband and BPSK is modulation of a carrier.
Re: BPSK
carrier.
Actually, there's even more of a difference.
In BPSK, a 1 or a 0 is determined by a single phase shift from the carrier =
frequency. The modulation is either in phase with the carrier or it is 180 =
(or theoretically any other) phase different from the carrier, and each of =
those states represents one bit.
In Manchester, instead, you need both the "0 phase" and the "180 phase" sta=
tes (in quotes because I'm relating phase to high and low) to represent a s=
ingle bit of information.
Re: BPSK
Are you distinguishing it by frequency? Consider that RF goes down to
60kHz (used to be 20kHz but I think that one shut down).
In general, there can be any frequency relationship
between the carrier and modulating frequency.
In the synchronous case, there is a definite relation
between the two, usually that the carrier is an integer
multiple of the modulation rate, or possibly a simple
fraction.
Manchester is the special case where the modulation (bit rate)
is at the same frequency as the carrier, and (if the
carrier is considered as sine) either 0 or 180 degree
phase shift.
That is, you have a whole cycle of either sin(wt) or
sin(wt+pi). It is baseband in the sense that the
sidebands can be considered as going down to 0Hz.
-- glen
Re: BPSK
On Fri, 26 Oct 2012, in the Usenet newsgroup comp.dcom.lans.ethernet, in article
Huh?   I suppose you are referring to the frequency standard stations
WWVL (was on 20 KHz), WWVB (on 60 KHz) from Fort Collins, Colorado
(USA) and GBR and/or MSF (was Rugby, England, now moved to Anthorn,
England), but these are not the only very low frequency stations still
in regular use. GQD (Anthorn, England) is operating on 19.6 KHz, and
there are several US Navy transmitters (NAA in Cutler, Maine, NLK in
Jim Creek, Washington among others) in the range 17 to 23 KHz.
Not withstanding the above, the International Telecommunications Union
defines radio services down to 9 KHz (the band 9 to 14 KHz is for
radio navigation services, such as the now retired "Omega" system - see
<http://en.wikipedia.org/wiki/Omega_ (navigation_system)> for details -
the band 14-19.95 KHz is "Maritime", 19.95-20.05 KHz is "Standard
Frequency and Time Signals", 20-70 KHz is "Maritime" and so on) and the
fact that few stations use those bands in no way changes the definition
of "radio frequencies".
If you look back in the archives of "comp.protocols.time.ntp", you'd
find Prof. Mills (RFC5906 and others) ranting about the interference
(4th harmonic) from analog television _receivers_ making WWVB unusable
in Deleware.   Don't know if that's still the major problem it was.
        Old guy
Site Timeline
