Ethernet LAN baffling speed problem
Subject Author Date
baffling speed problem Tim Smith 07-23-05
Posted by Tim Smith on July 23, 2005, 5:52 am
We've got a weird speed problem at work. Here's the setup:
wireless link to our main building
v
wireless hardware on our building
v
router
v
switch
v
hub
There are a bunch of computers connected to the switch, and a bunch
connected to the hub. Here's what we see on *most* of our computers:
1. Connections between computers in our building are fast.
2. Uploading data from our building to the main building is fast. (Around
1.2 megabytes/second, which is the expected speed of the wireless link).
3. Downloading data from the main building to ours is slow (30 kbytes/second
is common, with frequent fluctuations up to around 80-100 kbytes/second, and
occasional bursts up to 1 megabyte/second).
I said "most of our computers", because some get fast downloads. I have a
test lab, which has more computers than there are network jacks in the room,
so I brought in an unused DLink home router/switch from home, and am using
the switch portion of it. So, one of the network jacks is connected to one
of the 4 "LAN" ports on the router, and then 3 test computers are hooked to
the others. These all get fast downloads.
Upon experimenting around the building, what we've basically found is this:
1. If a computer is plugged into a network jack, it is slow to download
(except for a single exception, which I'll cover later). It doesn't matter
where that jack connects to on the other end--we've tried moving the other
end from the hub to the switch, or the switch to the hub. It's slow no
matter what.
2. If we take one of the slow computers, and instead of plugging it directly
into the wall jack, we plug it into a cheap switch, and plug the switch into
the wall jack, that computer gets fast downloads.
3. It doesn't seem to have anything to do with the OS. We see this on
Windows, Linux (SuSE and Gentoo), and my PowerBook. It doesn't seem to be a
specific brand of network card in the PCs, either...we've got a variety of
onboard and add-in cards.
The one exception is there is one Windows box that is fast even when plugged
straight into the wall jack. It's specific to that computer--if we unplug
the cable from the back of it and move it over to my PowerBook, for example,
my PowerBook is slow (and then if we stick a switch between the PowerBook
and the wall, the PowerBook is fast).
We also tried using a hub instead of a switch between the computers and the
wall. They stayed slow. (And if we went "computer -> switch -> hub ->
wall", they were fast).
(Oh, and it isn't something freaky about the wiring between the jacks and
the hub or switch, because it was slow when we took my PowerBook into the
wiring closet and plugged it right into the hub with a short cable that is
known to be good).
It would seem that the fact that it only affects downloads from the other
building would indicate a problem with the wireless hardware, or the router.
However, if the problem is on that side of the switch, then it would seem
that it would not be affected by whether or not the computers go through an
extra switch between them and the wall jacks. Conversely, it would seem
that anything that would be affected by that would affect internal traffic
as well as traffic from the other building.
Anyone have any ideas as to what the heck could be going on here?
--Tim Smith
Posted by Robert Redelmeier on July 23, 2005, 7:17 pm
> the jacks and the hub or switch, because it was slow when we
> took my PowerBook into the wiring closet and plugged it right
> into the hub with a short cable that is known to be good).
This would have been my first guess. Asymmetric speed on a
symmetric link is often due to a homemade cable with a split pair.
You talk of "downloading files" but it would be good to
eliminate the protocol as a possible cause. Try some tests
with ttcp and ping.
-- Robert
Posted by Walter Roberson on July 24, 2005, 7:36 pm
:We've got a weird speed problem at work. Here's the setup:
:2. Uploading data from our building to the main building is fast. (Around
:1.2 megabytes/second, which is the expected speed of the wireless link).
:3. Downloading data from the main building to ours is slow (30 kbytes/second
:is common, with frequent fluctuations up to around 80-100 kbytes/second, and
:occasional bursts up to 1 megabyte/second).
Assymetric speeds often indicate a duplex problem.
"Never install telephone wiring during a lightning storm." -- Linksys
Similar ThreadsPosted
baffling speed problem July 23, 2005, 5:52 am
Network Speed Question September 2, 2006, 5:31 am
network card speed February 8, 2007, 10:32 am
Software to test network speed? September 9, 2004, 9:05 pm
slow TCP connections due to very different speed of segments? March 10, 2005, 5:08 am
Speed limit of Fast Ethernet November 22, 2005, 7:39 am
file transfer speed in a network October 11, 2006, 4:45 am
Switch / Server - speed / duplex February 28, 2007, 10:01 pm
Routers, switches & network speed? August 27, 2007, 4:01 pm
query on port speed specification January 5, 2008, 7:37 am
Auto-negotiation and traffic flow between different speed ports December 6, 2005, 8:15 am
120 Hosts Running GigE at Wire Speed Minimum Cost February 26, 2005, 2:07 am
FPGA based Ethernet network analyzer - full wire speed, programmable February 10, 2006, 9:38 pm
Routing problem December 12, 2005, 9:48 pm
Problem with WAP and LAN connection September 4, 2006, 7:21 am
