Hallo group,
is the following scenario possible:
I want to connect 14 computer with GBit LAN via a GBit-Switch. Each of the computers should get his IP via DHCP (the switch should act as DHCP server). Every assigned IP address should depend on the port where the computer is connected.
for example: computer 1 is connected to port 1 of the switch and gets IP address
192.168.x.1, computer 2 is connected to port 2 of the switch and gets IP address 192.168.x.2, computer 3 is connected to port 3 of the switch and gets IP address 192.168.x.3, .... computer 14 is connected to port 14 of the switch and gets IP address 192.168.x.14 via the DHCP Server running on the switch.Is it possible to configure the DHCP server within the managed layer 2 or layer 3 switch to assign IPs depending on the connected port? Is it possible use VLANs to get the same effect?
Thanks Chris
